It is currently Tue Aug 12, 2025 2:28 am
PostPosted: Sat Apr 09, 2016 1:32 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I recently got my first full size neck blank, mainly because I was tired of laminating the blocks to stack for the heel and I've never been happy with the look I was getting doing so. I'm ready to cut the blank but I got thinking about whether I still needed to scarf the head or not. Is the scarf joint for strength or for ease of setting the correct angle of the head?
Has anyone done this both ways and if so what's the preference. If not then what's a good reason not to have one solid piece neck?
PostPosted: Sat Apr 09, 2016 2:28 pm
Last Name: Sollod
If you get a 3"x4"x30" neck blank. I see no reason to cut a scarf joint. I would simply cut out 2 solid neck blanks with angled heads. I typically add a volute which strengthens that area...
www.swiftcreekguitars.com
PostPosted: Sat Apr 09, 2016 2:37 pm
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
Same here,i just cut 2 necks from one 3×4 blank ,never liked scarf joints and stacked
heels .
PostPosted: Sat Apr 09, 2016 3:07 pm
You want a blank with the grain lines perpendicular to the fingerboard surface this yields the strongest transition going to the head stock slope. When the truss rod adjuster is at the HS end I'd argue that a scarf joint is stronger and a better choice.
Ken Cierp
PostPosted: Sat Apr 09, 2016 3:56 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
If you think you will be working from full size neck blanks in the future and you have a band saw, here's a simple jig you can make and use to get an accurate, square, and smooth cut of the headstock angle on the headplate face:
http://luthiersforum.com/forum/viewtopic.php?f=10117&t=45211
PostPosted: Sat Apr 09, 2016 5:33 pm
" what's a good reason not to have one solid piece neck?"
1. less waste - even nesting two necks will leave the center section between them as scrap. From the scrap you may get tail blocks, side reinforcements, or what have you so the frugal minded still won't send much to the bin.
2. Better grain orientation with scarf joint.
3. Peghead can be worked on separately with modified bridle joint.
4. Economy - the board foot price for 4/4 rough cut stock is generally cheaper than 12/4 stock.
I like to do the bridle joint peghead and a "block" heel glued to a separate neck shaft. I also don't care for the look of the stacked heel, although when well done they don't look bad. A single block glued to the shaft is a compromise. I like to rough shape the peghead before gluing to the neck, so I prefer the bridle joint (which I also think is stronger than a one piece).
To each their own, there are plenty of one piece necks that have held up fine.
PostPosted: Sun Apr 10, 2016 4:10 pm
I scarf, but I don't think the concept that a scarf joint is stronger than a one piece neck is clear cut.
When you look at the location of most headstock breaks, they are in the transition zone between neck shaft and headstock.
Most people are locating their scarfs just beyond the e tuner holes(I do it in the neck/volute zone), so effectively the breaks occur before the scarf joint.
When it comes to break resistance some of the major factors are IMHO
-don't do the Gibson style truss rod nut access
-don't do classic Gibson 17 degree headstocks, even 15 is not really necessary, I use 13
-don't have any runout relative to the fretboard surface of the neck, if you stack 10 degrees here on top of 15 at the headstock you will have serious short grain in the headstock.
PostPosted: Sun Apr 10, 2016 7:01 pm
My classical Kohno 30 neck/head is from a solid block. It's a top of the line guitar. Heel is built up (one piece) and the interior block is separate. I assume there is a spline joining at the body.
PostPosted: Sun Apr 10, 2016 8:18 pm
First name: Jim
Last Name: Kirby
OMG what a waste of wood. I'm so glad I build in the classical world where stacked heels are the norm and our blanks are 1 by 3 by 30. If I had a 3 by 3 by 30 blank in hand, I'd resaw it into 3 1 by 3 by 30 blanks quickly and have 3 guitar necks instead of 2.
Jim Kirby
kirby@udel.edu
PostPosted: Sun Apr 10, 2016 9:32 pm
First name: Jay
City: Bothell
State: Washington
To be fair, that drawing greatly exaggerates the size of the leftover piece in the center. See the photo below for a better idea of its actual size. I have found ways to use that center piece so it's not actually wasted.
These users thanked the author J De Rocher for the post: kencierp (Sun Apr 10, 2016 9:36 pm)
PostPosted: Sun Apr 10, 2016 9:38 pm
Exactly
Ken Cierp
PostPosted: Sun Apr 10, 2016 11:13 pm
First name: Joey
Last Name: Holliday
City: Palmetto
It comes to about 20 extra bucks for 2 solid cut yourself necks vs. scarf and stack blanks. To me the aesthetics are worth it. Also- who doesn't love to have scrap mahogany laying around? I love the stuff and the scraps are welcome for all types of appointment design ect.
PostPosted: Mon Apr 11, 2016 5:51 am
First name: Jim
Last Name: Kirby
Yes, the piece left in the middle can be used for end blocks or other things. Actually, given that the blanks are 3 by 4 rather than 3 by 3, I'd get 4 necks with not enough left over for anything.
As far as aesthetics, I admit to being a product of my chosen building path. I like the stacked heel better than a solid heel. Go figure.
Jim Kirby
kirby@udel.edu
Users browsing this forum: Bing [Bot], meddlingfool and 41 guests
cron
